Date/Time: Thu, 09 Jan 2025 08:28:24 +0000
Gain Data Feed
View Count: 967
[2016-08-05 09:55:20]
User78442 - Posts: 260
My data is not connecting. Do you have a problem from Gain?
[2016-08-05 09:57:01]
I will send a log for analysis
[2016-08-05 10:50:57]
This looks like a firewall issue:
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-08-05 10:56:16
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-08-05 10:56:16
GainCapital FIX Trading socket (29) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-08-05 10:56:36
GainCapital FIX Trading socket (29) | Shutdown and closed. | 2016-08-05 10:56:36
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-08-05 10:56:36
Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.2
[2016-08-05 11:06:30]
OK, I've added SC to the allowable apps to pass thro' Windows Firewall - Let's see ...
