Date/Time: Thu, 09 Jan 2025 08:39:08 +0000
Alert when rectangle fully crossed
View Count: 783
[2016-08-04 19:55:01] |
phaedonk - Posts: 352 |
Is there an alert that only triggers when a rectangle has been completely crossed by price? I would think that (when price is coming down and meets a rectangle) if I select Below in comparison, it should only trigger when price moves to one tick below the rectangle. However, this does not seem to be the case; SC treats it as a line and triggers on contact. Is this possible? I have also tried full bar and crossing. Edit: Also, can you please make it that the list in "Tool config for Appearance when true" shows the aliases we use for the configurations and not just numbers? This would be very helpful. Date Time Of Last Edit: 2016-08-04 20:15:44
[2016-08-05 05:30:56] |
You really need to set up a separate single Line and set an Alert on that. Edit: Also, can you please make it that the list in "Tool config for Appearance when true" shows the aliases we use for the configurations and not just numbers? This would be very helpful. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-05 09:22:59] |
Regarding the Tool config for appearance: I save it so it changes every time a drawing of that configuration is hit, but it doesn't get saved. When it is used again it reverts to None. What is the point?
[2016-08-05 10:55:37] |
You can only change this through Global Settings >> Tool Configs >> [Tool] >> A. The documentation should already explain this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
