Date/Time: Thu, 09 Jan 2025 09:15:14 +0000
Running multiple TWS accounts in multiple instances of SC
View Count: 975
[2016-08-04 19:04:32]
User713273 - Posts: 409
http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#MultipleTWSInstances
Hi, Im unclear on what "Server box" is referencing in Dat/Trade Service Settings. Is this Server Port?
[2016-08-04 19:33:57]
This is referring to "Server" in the list on the left of the Data/Trade Service Settings window.
[2016-08-04 21:27:21]
Yes, this is understood. I see "Server Address", "Server Port", which is the appropriate field?
I have set Edit >> Global Configuration >> API >> Settings >> Socket Port to 7497.
Thx for the help on this
[2016-08-04 21:36:42]
You need to set the Server in the Interactive Brokers settings in File >> Data/Trade Service Settings to 127.0.0.1:7497
[2016-08-04 22:12:08]
Please review, still having an issue. thx
Interactive Brokers | Connecting to the server 127.0.0.1. Port 7497 | 2016-08-04 15:09:05
Socket (80) | Connected. | 2016-08-04 15:09:05
Interactive Brokers | Connected to server. | 2016-08-04 15:09:05
Interactive Brokers | Sending Encoding Request to server | 2016-08-04 15:09:05
Socket (80) | Closed. No error. | 2016-08-04 15:09:05
Socket (80) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2016-08-04 15:09:05 *
Socket (80) | Shutdown and closed. | 2016-08-04 15:09:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-04 15:09:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-04 15:09:05
Interactive Brokers | Disconnected. | 2016-08-04 15:09:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-04 15:09:05
imageimage (2).png / V - Attached On 2016-08-04 22:11:39 UTC - Size: 208.45 KB - 240 views
imageimage (3).png / V - Attached On 2016-08-04 22:11:48 UTC - Size: 498.91 KB - 228 views
[2016-08-04 22:18:55]
You need to install another copy of Sierra Chart following the instructions here:
Using Multiple Data and Trading Services at the Same Time
And set Sierra Chart to use Interactive Brokers:
Interactive Brokers Trading Service: Setup Instructions
