Date/Time: Thu, 09 Jan 2025 08:40:56 +0000
Extended hours session
View Count: 661
[2016-08-03 14:23:29] |
User26753 - Posts: 43 |
How can I see and don't see the extended hours of trading USA stocks?
[2016-08-03 17:25:31] |
You need to enable Chart >> Chart Settings >> Use Evening Session. Refer to: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
