Date/Time: Thu, 09 Jan 2025 08:33:34 +0000
SierraChart - Reference to an other chart
View Count: 788
[2016-08-03 13:07:35] |
FerroTrader - Posts: 70 |
Hello, I would like to access data from an other chart within my currenty study (i.e. into chart 1 do some actions if data from chart 2 confirms them): how could I do that ? I have searched out it on the docs here rpovided but with few success. Thanks Andrea |
[2016-08-03 17:02:30] |
This can be done by using the Study/Price Overlay study: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-04 07:50:27] |
Hello, thank you. My goal would be to get data from an other chart using ASCIL, is that possible ? For instance, inside and automated trading strategy, I would like to enter a position on the ES once and only once a certain condition happens on the NQ. is this possible using ASCIL coding ? if yes, could you please pointing me the functions ? thanks Andrea |
[2016-08-04 16:27:34] |
Refer to: Referencing Other Time Frames and Symbols When Using the ACSIL Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
