Date/Time: Thu, 09 Jan 2025 09:06:50 +0000
Alert study
View Count: 821
[2016-08-02 20:17:35] |
User26753 - Posts: 43 |
Sorry, but I find very difficult to place the alert I want following the instructions of Colour Bar Based on Alert Condition. I want to place a down triangle on top of the bar when momentum study (5) crosses below zero line I want to place an up triangle on down of the bar when momentum study (5) crosses above zero line Could you please tell me the instructions to get this alert condition in the chart? In case of negative maybe you can tell me about some private Sierra developer who can help me |
[2016-08-02 22:37:42] |
Sawtooth - Posts: 4147 |
Try this: Add two instances of the Color Bar Based On Alert Condition study, one for each direction. For the up triangle at low of bar: Set the 'Output When Condition True' to 'Use Input Data' Set the 'Input Data' to Low Set the Draw Style to Triangle Up Use this formula on the Alerts tab: =CROSSFROMBELOW(ID1.SG1,0) where ID1 is the momentum study, edit as needed For the down triangle at high of bar: Set the 'Output When Condition True' to 'Use Input Data' Set the 'Input Data' to High Set the Draw Style to Triangle Down Use this formula on the Alerts tab: =CROSSFROMABOVE(ID1.SG1,0) where ID1 is the momentum study, edit as needed Date Time Of Last Edit: 2016-08-03 00:43:50
[2016-08-03 06:06:50] |
Refer to our response for this here: Add an arrow or a dormir to an study alert | Post: 96252 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
