Date/Time: Tue, 21 Jan 2025 00:46:46 +0000
Time and Sales Color Row
View Count: 1684
[2016-08-02 04:06:47]
User150371 - Posts: 70
The settings have the option to color a row if a certain condition is met , eg Volume > 50. But I would like to have a different color row highlight for Bid and Ask trades,for quick visual reference. Could you add this option ? In a fast moving market it takes to long to look at the Type column and see if the highlighted row was a Bid or an Ask trade. Thanks.
[2016-08-02 05:21:39]
We would have to check but we think this is already on our task list of things to do. We will try to get this done soon.
Date Time Of Last Edit: 2016-08-02 05:21:53
[2016-08-03 02:40:00]
This will be out in the next release.
[2018-07-17 14:34:19]
whats1thingnow - Posts: 407
for this 'time and sales bid/ask highlight color', i think there might be a bug?
not sure what causes it (i think it's when i restart the sierra program), it seems to always reset it back to navy blue for both bid highlight color, and ask highlight color...
please fix?
thanks!~
Date Time Of Last Edit: 2018-07-17 14:35:17
image2018-07-17_0730.png / V - Attached On 2018-07-17 14:35:13 UTC - Size: 10.85 KB - 429 views
[2018-07-17 18:52:08]
We are checking this.
[2018-07-18 08:39:18]
SC Developer - David - Posts: 661
Make sure that if Chart >> Graphics Settings >> Use Global Graphics Settings Instead of These Settings is unchecked, then the Time ans Sales: Bid/Ask Highlight Color settings are specified in chart specific graphics settings window, otherwise in Global Settings >> Graphics Settings - Global window.
Date Time Of Last Edit: 2018-07-18 08:40:06
[2018-07-19 02:47:47]
Yes, i have Chart >> Graphics Settings >> Use Global Graphics Settings Instead of These Settings is unchecked.
And yes, I've the Time ans Sales: Bid/Ask Highlight Color set to red and green respectively.
However, after a few days, both the colors would go back to navy blue (the default?).
[2018-07-22 02:44:20]
please fix?
thanks!~
bug happened again after i restarted sierra charts
[2018-07-24 06:59:04]
So you are setting these colors on the chart itself and they are changing for a specific chart after reopening the Chartbook? This cannot be associated with restarting Sierra Chart.
Attach the particular chart this is occurring with, by following these instructions here:
Date Time Of Last Edit: 2018-07-24 07:09:07
