Date/Time: Thu, 09 Jan 2025 08:49:00 +0000
Cumulative Delta indi with FLAT Candlestick bars.
View Count: 1689
[2016-08-02 03:00:08] |
User572839 - Posts: 3 |
How to set CD indi so candelstick bars are shown flat on a zero line ?
CD-Flat Cnadles.jpg / V - Attached On 2016-08-02 02:59:10 UTC - Size: 188.82 KB - 2546 views |
[2016-08-02 04:56:59] |
If you want to add a zero line, follow the instructions here: Chart Studies: Adding a Horizontal Line to an Existing Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-02 15:09:26] |
Just added a zero line but, how do I set the cumulative delta indi to show every candle starting from that zero line like in the image I posted ? |
[2016-08-02 15:17:51] |
Use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s291 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-02 15:50:36] |
That shows what I want, thanks alot !
