Date/Time: Thu, 09 Jan 2025 08:36:42 +0000
i am not getting any of the options on the installer anymore.
View Count: 610
[2016-08-01 21:47:21] |
kinghat - Posts: 120 |
here is an image showing they are grayed out.
wDfPXnK.png / V - Attached On 2016-08-01 21:47:07 UTC - Size: 20.63 KB - 254 views |
[2016-08-01 22:03:07] |
The shortcut options will be disabled when updating directly from Sierra Chart. The option to run the program should be enabled and that is now fixed. When you update again, you will see that option enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
