Date/Time: Thu, 09 Jan 2025 09:12:38 +0000
Horizontal Lines Will Not Go Away
View Count: 616
[2016-08-01 20:20:19] |
User299392 - Posts: 216 |
See attached - these horizontal lines just will not go away after this latest release. Can you please check? In the image attached - manage drawings window is also pulled and see how it shows no drawing but still these lines are showing in the chart? Please help! |
HorizontalLines Stuck.JPG / V - Attached On 2016-08-01 20:18:44 UTC - Size: 109.31 KB - 244 views |
[2016-08-01 20:59:57] |
Apparently they are added by a study. Remove the studies through Analysis >> Studies.
[2016-08-01 21:08:50] |
Even with all studies removed - these lines do not go away.
[2016-08-01 21:12:49] |
Therefore, these have been copied from another chart. Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-01 21:50:55] |
Agreed - thank you for your help.
