Date/Time: Thu, 09 Jan 2025 08:36:57 +0000
Extend IB lines?
View Count: 812
[2016-08-01 16:57:12] |
User341584 - Posts: 44 |
I have a 60 min Initial Balance study on chart. Is it possible to make the IB extension lines continue through out the day? Pic is included Thanks in advance. M |
Attachment Deleted. |
[2016-08-01 17:09:06] |
You need to set the Initial Balance Type to Daily: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s326 Also when posting an image of a chart, only use this method: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-01 17:11:44] |
Thank you for quick response. And gotcha, thank you! |
