Date/Time: Thu, 09 Jan 2025 08:46:31 +0000
Sierra Charts Crash when I enter certain symbols
View Count: 770
[2016-08-01 13:59:33] |
User786203 - Posts: 18 |
Hello, Why would my Sierra Chart program crash when I enter certain stock symbols? For example, this morning I entered TOPS which is a US traded stock and every time I entered it the program froze and had to be restarted. It has happened a few times over the past few weeks. Most symbols work fine, but sometimes I enter a symbol and it crashes. Please let me know any possible solutions as this is very frustrating while trading. Thanks |
[2016-08-01 16:02:30] |
Are you using the Volume by Price study on those charts? Also, is this an Intraday or Historical Daily chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-02 03:04:41] |
Yes. I am using Vol by price.
[2016-08-02 04:00:44] |
You will need to increase the Volume at Price Multiplier: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.23 Also soon, this kind of issue will not cause Sierra Chart to freeze because of how Historical Daily data will be loaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-02 12:43:21] |
Ok. By changing the multiplier does that affect the volume by price data on other charts that currently load normally?
[2016-08-02 15:09:57] |
It will affect other symbols within the same chart. You really have to be careful with using the Volume by Price study on a Historical Daily chart, which we assume you are using, and changing the symbol. You can definitely run into trouble like you have. Would be best to use an Intraday chart: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-02 15:10:11
[2016-08-03 12:58:14] |
Can I use the intraday chart on a daily chart? The way I have my charts linked is that my intraday charts are linked to a daily chart. This way when I change the symbol once all of the charts change at the same time. I tried changing the daily chart to intraday, but as soon as I click Daily time period it automatically switches it back to historical. Thoughts? |
[2016-08-03 17:08:56] |
You can create Daily bars from Intraday data as these instructions explain: Chart Session Times: Creating Daily Bars with Custom Session Times Also set Chart >> Chart Settings >>Chart Data Type to Intraday Chart Only. This is the best way when using the Volume by Price study with daily bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-03 17:09:13
[2016-08-04 13:02:08] |
Nice. That combo worked. I was able to load the ticker TOPS without it crashing. Thanks! |
