Date/Time: Thu, 09 Jan 2025 08:30:34 +0000
New to SierraCharts
View Count: 617
[2016-08-01 12:47:11]
User976133 - Posts: 38
Good morning,
I am new to SierraCharts (SC) and am brought here by Infinity Futures.
As part of my account at Infinity, it includes SC ver 5.
I have been told that it cannot link to other data suppliers - TD Ameritrade.
Can anyone verify this as fact?
If it can not link to TDA, that would mean a new license to SC? Which one? My goal is stock/index option trading.
Is there any problem running TDA and Infinity linked versions at the same time on the same computer?
Are there any other questions you can think I should ask?
Thanks for your thoughts and guidance.
[2016-08-01 16:48:02]
Yes this is correct. You need to use your own direct account:
Direct Sierra Chart Account
You can use either service package 3 or 5. You can use multiple versions of Sierra Chart on the same computer.
