Date/Time: Thu, 09 Jan 2025 08:51:48 +0000
vector unique among all instances of a study
View Count: 877
[2016-07-31 16:27:04]
@sstfrederik - Posts: 404
Hi, a beginner developer question ...
How can i make sure that a vector is not shared among all loaded instances of a study?
At first I used static std::vector, but this gives problems with more instances of a study using the same vector.
Than I used std::vector which work when sc.FreeDLL = 1; but not when set to 0;
I declared these outside the scsf_
std::vector <SCString> f_DataLines;
std::vector <std::vector <char*> > f_DateValues;
[2016-07-31 18:06:59]
disregard.
placing the code inside scsf_ works fine.
