Date/Time: Thu, 09 Jan 2025 08:57:55 +0000
Indicating "Data loading" when processing larger server file
View Count: 665
[2016-07-30 17:56:35] |
@sstfrederik - Posts: 404 |
Hi, I am loading a rather large file from a server containing ~40k lines of csv data. Is there a way to indicate on screen that the study is loading this data and provide a percentage loaded indication. Just like what is used when a chartdata is loaded. Also when chart data is loaded SC remains responsive. During this study load SC can become unresponsive while loading this data. Do you have any pointers on limiting resource allocation during this process so that SC stays responsive. I am looking for a cleaner way to load larger files. Thanks |
[2016-07-30 18:35:13] |
If you are referring to your own custom study loading its own data, we cannot help with any of these requests.
