Date/Time: Thu, 09 Jan 2025 08:32:27 +0000
multiple trade windows for different ib accounts
View Count: 743
[2016-07-29 19:01:04] |
User25244 - Posts: 123 |
I hav 2 accounts with IB would like a trade window for both of them Is this possible? and if so how is this accomplished? Ty |
[2016-07-29 19:35:42] |
If both of these accounts are on the same Interactive Brokers username or main account, then they will both be listed on the Trade Window and you can select either one. Here are instructions: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Internally the way that this is managed is rather complicated because of limitations with Trader Workstation but it does work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-29 20:07:22] |
they are not under same still possible? |
[2016-07-29 21:58:55] |
Yes this is possible. Just install another copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Here are specific instructions: Interactive Brokers Trading Service: Running Multiple TWS Instances Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
