Date/Time: Thu, 09 Jan 2025 19:15:19 +0000
Price Display Format and Tick Size
View Count: 1232
[2016-07-27 15:07:16] |
sigmadict - Posts: 95 |
Hello, When I make the Future Rollover on my Charts, the Chart updates to the new Contract. When that happens, in the Chart Setting, the Price Display Format and the Tick Size of my charts went back to default. I want to know if it is possible to save the Chart Settings, so all the different Charts keep their own Settings (Price Display and Tick Size). I want the Settings to stay the same for all the different Charts in the Chartbook, not only for the Symbol, or Contract, or Chartbook, but in each Chart alone. Is it possible to do that, and if not, do you think Sierra could make this option possible in the Chart Settings by saving the Chart Settings like for example a Study Collection ? Thanks Regards |
[2016-07-27 17:32:04] |
You need to change the defaults that you want to use through the Global Symbol Settings: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-09 04:08:03] |
Hello, Thanks for the response. Do you think it could be valuable to have Chart Settings Collection to save different parameters for different setups, not only for default parameters ? Thanks Regards |
[2016-08-09 05:16:04] |
Perhaps, but there is no chance this is going to happen for years. We are already behind with with at least 18 months of development. Refer to: Notice: Suggestions (Currently not accepting) It is pointless to even ask. You need to use different charts with their own independent settings to accomplish what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-09 05:16:44
