Date/Time: Thu, 09 Jan 2025 08:46:21 +0000
Only one limit order per day
View Count: 828
[2016-07-27 14:41:30] |
pkhst958 - Posts: 57 |
Hi, I would like to send only one Limit order per day to ib. Working orders (J3) shows 0 with one Limit order active. Is there a cell I can use to stop sending additional orders to ib after the first Limit order is sent?
[2016-07-27 17:08:03] |
Not sure exactly how you would do this using Spreadsheets but have a look at this cell: https://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php#CellJ52 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-27 17:08:12
