Date/Time: Thu, 09 Jan 2025 08:31:25 +0000
Is there a way to graphically present your daily p/l like NT?
View Count: 1046
[2016-07-27 12:06:00] |
User554317 - Posts: 59 |
I like the way NT can graphically present your daily p/l with bars. Is there a way to do this in SC other than just display p/l numbers? Here is a screenshot of what I mean. |
07.27.2016-07.59.png / V - Attached On 2016-07-27 12:05:40 UTC - Size: 48.79 KB - 348 views |
[2016-07-27 16:59:36] |
Yes this is supported: Trading Information Windows: Trade Data Studies Although it will just be a single line, not bars. To create bars use the Study Overlay-OHLC study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s149 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-27 17:00:34
[2016-07-29 12:29:44] |
Ok sounds like there is no easy way to do this. As an aside is there a way to display every day's p/l over a period of time? |
[2016-07-29 12:49:09] |
Sawtooth - Posts: 4147 |
You can do it on a daily chart, with the Position Profit/Loss set to Currency, using the Trading:Daily Profit/Loss study, with the Draw Style set to Bar, and the Auto-Coloring set to Based on +/-
[2016-07-29 12:52:15] |
Ok thanks Tom. Is there no prettier way of doing this through the reports, rather than having to muck around on a chart with this stuff? And would it show p/l from all instruments rather than just the one I'm drawing the graph on? I find it amazing that with all this great reporting in SC, displaying the daily P/L is not one of them... |
[2016-07-30 03:26:58] |
It would only show individual symbol's P/L. You could combine multiple instruments on a spreadsheet study, and display it on a chart, but you'd need a chart for each instrument. This is the only way to plot P/L as bars, without developing a custom study in c++/ACSIL. |
[2016-08-01 08:30:35] |
You will need to use the Trading: Daily Profit/Loss study: Trading Information Windows: Trade Data Studies However, it is only for a single symbol and trade account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-02 03:27:12] |
User948528 - Posts: 108 |
This has been a much requested feature for many years, SC please consider doing it for your users.
