Date/Time: Thu, 09 Jan 2025 08:51:54 +0000
How to make Chart settings the global default?
View Count: 750
[2016-07-27 10:28:19] |
User554317 - Posts: 59 |
Whenever I open a new chart/dom I have to redo all the chart settings. Is there a way to set a certain default or can I find it in global settings somewhere? Thanks |
[2016-07-27 10:35:08] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-27 12:02:30] |
Thank you
