Date/Time: Thu, 09 Jan 2025 08:46:55 +0000
detailed logging
View Count: 684
[2016-07-26 09:34:15] |
Sporken - Posts: 82 |
Hi, My charts are unresponsive again and I'm not sure what is causing it. Is there a way to enable detailed logging so I can see what is causing the unresponsive behaviour? Thanks, -Jason |
[2016-07-26 16:20:22] |
No there is not detailed logging for this. Refer to help topic 30: Https://www.sierrachart.com/index.php?l=helpdetails30.html Clearly there are study configurations you are using which are causing high CPU usage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
