Date/Time: Thu, 09 Jan 2025 09:00:55 +0000
Background color of P/L & Day P/L column in Trade Window
View Count: 773
[2016-07-26 06:09:53] |
NumbersBars - Posts: 141 |
version: 1446 Is it possible to change or grey out background of P/L and D:P/L column of Trade Window? Please refer to the attached image for the column location. |
Private File |
[2016-07-26 06:16:26] |
Yes there are color settings for these in Global Settings >> Graphics Settings: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php The color settings are: Chart Trade Window Position* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-26 06:55:48
[2016-07-26 06:29:54] |
Could you check the URL you have provided? It leads me back to Sierra Chart main page.
[2016-07-26 06:56:13] |
Use this link: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-26 06:56:33
