Date/Time: Thu, 09 Jan 2025 08:36:26 +0000
new account
View Count: 912
[2016-07-25 20:33:04]
User568539 - Posts: 18
Hi. I am not able to connect to live trading with Sierra Chart. Thank you.
[2016-07-25 20:40:04]
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-07-25 20:44:43]
Reading Internal Order ID file. | 2016-07-25 13:37:15
Reading Trade Orders file. | 2016-07-25 13:37:15
Reading Trade Positions file. | 2016-07-25 13:37:15
Software version: 1446 | 2016-07-25 13:37:15
Uses New Spreadsheets | 2016-07-25 13:37:15
Enabled for: Advanced Features. | 2016-07-25 13:37:15
Enabled for: Sierra Chart Historical Data Service. | 2016-07-25 13:37:15
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-07-25 13:37:15
Current selected Data/Trading service: CQG FIX Trading | 2016-07-25 13:37:15
Chart Update Interval: 500 | 2016-07-25 13:37:15
Data/Trade Service Settings automatically set. | 2016-07-25 13:37:15
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-07-25 13:37:15
2016-07-25 13:37:40 Local computer time | 2016-07-25 13:37:15
2016-07-25 20:37:40 Local computer time in UTC | 2016-07-25 13:37:15
2016-07-25 13:37:40 Local computer time in SC Time Zone | 2016-07-25 13:37:15
2016-07-25 20:37:34 Server time in UTC | 2016-07-25 13:37:15
Local computer UTC time and Server UTC time difference: 5 seconds. | 2016-07-25 13:37:15
Program path: C:\SierraChart\ | 2016-07-25 13:37:15
Data Files path: C:\SierraChart\Data\ | 2016-07-25 13:37:15
OS Version Number: 6.1 | 2016-07-25 13:37:15
Locale Setting: C | 2016-07-25 13:37:15
Checking for new symbol settings for cqg | 2016-07-25 13:37:15
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-07-25 13:37:15
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-07-25 13:37:15
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-07-25 13:37:15
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-07-25 13:37:41
Symbol settings are up-to-date for cqg | 2016-07-25 13:37:41
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:37:45
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:37:45
socket (4) | Connected. | 2016-07-25 13:37:45
socket (4) | Starting TLS 1.2 connection. | 2016-07-25 13:37:45
socket (4) | SSL connection established. | 2016-07-25 13:37:45
CQG FIX: Sending the Logon message. | 2016-07-25 13:37:45
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:37:46
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:37:46
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:37:46
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:37:46
CQG FIX | FCM name: AMP | 2016-07-25 13:37:46
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-07-25 13:37:46
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-07-25 13:37:46
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:37:46
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-07-25 13:37:46
CQG WebAPI websocket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:37:47
CQG WebAPI websocket (5) | Shutdown and closed. | 2016-07-25 13:37:47
CQG WebAPI | Websocket closed. | 2016-07-25 13:37:47
CQG FIX Trading | Websocket closed. | 2016-07-25 13:37:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:37:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:37:47
CQG FIX: DisconnectFIX called. | 2016-07-25 13:37:47
CQG FIX: Sending a Logout message. | 2016-07-25 13:37:47
CQG FIX Trading | Disconnected. | 2016-07-25 13:37:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:37:47
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:37:47
socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:37:47
socket (4) | SSL has been shut down. | 2016-07-25 13:37:47
socket (4) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:37:47
socket (4) | Shutdown and closed. | 2016-07-25 13:37:47
CQG FIX: Disconnected. | 2016-07-25 13:37:47
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:37:50
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:37:50
socket (6) | Connected. | 2016-07-25 13:37:50
socket (6) | Starting TLS 1.2 connection. | 2016-07-25 13:37:50
socket (6) | SSL connection established. | 2016-07-25 13:37:50
CQG FIX: Sending the Logon message. | 2016-07-25 13:37:50
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:37:50
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:37:50
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:37:50
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:37:50
CQG FIX | FCM name: AMP | 2016-07-25 13:37:51
CQG WebAPI websocket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:37:57
CQG WebAPI websocket (7) | Shutdown and closed. | 2016-07-25 13:37:57
CQG WebAPI | Websocket closed. | 2016-07-25 13:37:57
CQG FIX Trading | Websocket closed. | 2016-07-25 13:37:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:37:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:37:57
CQG FIX: DisconnectFIX called. | 2016-07-25 13:37:57
CQG FIX: Sending a Logout message. | 2016-07-25 13:37:57
CQG FIX Trading | Disconnected. | 2016-07-25 13:37:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:37:57
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:37:57
socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:37:57
socket (6) | SSL has been shut down. | 2016-07-25 13:37:57
socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:37:57
socket (6) | Shutdown and closed. | 2016-07-25 13:37:57
CQG FIX: Disconnected. | 2016-07-25 13:37:57
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:38:00
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:38:00
socket (8) | Connected. | 2016-07-25 13:38:00
socket (8) | Starting TLS 1.2 connection. | 2016-07-25 13:38:00
socket (8) | SSL connection established. | 2016-07-25 13:38:01
CQG FIX: Sending the Logon message. | 2016-07-25 13:38:01
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:38:01
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:01
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:01
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:01
CQG FIX | FCM name: AMP | 2016-07-25 13:38:01
CQG WebAPI websocket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:38:07
CQG WebAPI websocket (9) | Shutdown and closed. | 2016-07-25 13:38:07
CQG WebAPI | Websocket closed. | 2016-07-25 13:38:07
CQG FIX Trading | Websocket closed. | 2016-07-25 13:38:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:38:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:38:07
CQG FIX: DisconnectFIX called. | 2016-07-25 13:38:07
CQG FIX: Sending a Logout message. | 2016-07-25 13:38:07
CQG FIX Trading | Disconnected. | 2016-07-25 13:38:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:38:07
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:38:07
socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:38:07
socket (8) | SSL has been shut down. | 2016-07-25 13:38:07
socket (8) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:38:07
socket (8) | Shutdown and closed. | 2016-07-25 13:38:07
CQG FIX: Disconnected. | 2016-07-25 13:38:07
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:38:10
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:38:10
socket (10) | Connected. | 2016-07-25 13:38:10
socket (10) | Starting TLS 1.2 connection. | 2016-07-25 13:38:10
socket (10) | SSL connection established. | 2016-07-25 13:38:11
CQG FIX: Sending the Logon message. | 2016-07-25 13:38:11
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:38:11
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:11
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:11
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:11
CQG FIX | FCM name: AMP | 2016-07-25 13:38:11
CQG WebAPI websocket (11) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-07-25 13:38:24
CQG WebAPI websocket (11) | Shutdown and closed. | 2016-07-25 13:38:24
CQG WebAPI | Websocket closed. | 2016-07-25 13:38:24
CQG FIX Trading | Websocket closed. | 2016-07-25 13:38:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:38:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:38:24
CQG FIX: DisconnectFIX called. | 2016-07-25 13:38:24
CQG FIX: Sending a Logout message. | 2016-07-25 13:38:24
CQG FIX Trading | Disconnected. | 2016-07-25 13:38:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:38:24
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:38:24
socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:38:24
socket (10) | SSL has been shut down. | 2016-07-25 13:38:24
socket (10) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:38:24
socket (10) | Shutdown and closed. | 2016-07-25 13:38:24
CQG FIX: Disconnected. | 2016-07-25 13:38:24
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:38:27
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:38:27
socket (12) | Connected. | 2016-07-25 13:38:27
socket (12) | Starting TLS 1.2 connection. | 2016-07-25 13:38:27
socket (12) | SSL connection established. | 2016-07-25 13:38:27
CQG FIX: Sending the Logon message. | 2016-07-25 13:38:28
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:38:28
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:28
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:28
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:28
CQG FIX | FCM name: AMP | 2016-07-25 13:38:28
CQG WebAPI websocket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:38:35
CQG WebAPI websocket (13) | Shutdown and closed. | 2016-07-25 13:38:35
CQG WebAPI | Websocket closed. | 2016-07-25 13:38:35
CQG FIX Trading | Websocket closed. | 2016-07-25 13:38:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:38:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:38:35
CQG FIX: DisconnectFIX called. | 2016-07-25 13:38:35
CQG FIX: Sending a Logout message. | 2016-07-25 13:38:35
CQG FIX Trading | Disconnected. | 2016-07-25 13:38:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:38:35
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:38:35
socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:38:35
socket (12) | SSL has been shut down. | 2016-07-25 13:38:35
socket (12) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:38:35
socket (12) | Shutdown and closed. | 2016-07-25 13:38:35
CQG FIX: Disconnected. | 2016-07-25 13:38:35
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:38:38
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:38:38
socket (14) | Connected. | 2016-07-25 13:38:38
socket (14) | Starting TLS 1.2 connection. | 2016-07-25 13:38:38
socket (14) | SSL connection established. | 2016-07-25 13:38:38
CQG FIX: Sending the Logon message. | 2016-07-25 13:38:38
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:38:38
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:38
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:38
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:38
CQG FIX | FCM name: AMP | 2016-07-25 13:38:38
CQG WebAPI websocket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:38:45
CQG WebAPI websocket (15) | Shutdown and closed. | 2016-07-25 13:38:45
CQG WebAPI | Websocket closed. | 2016-07-25 13:38:45
CQG FIX Trading | Websocket closed. | 2016-07-25 13:38:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:38:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:38:45
CQG FIX: DisconnectFIX called. | 2016-07-25 13:38:45
CQG FIX: Sending a Logout message. | 2016-07-25 13:38:45
CQG FIX Trading | Disconnected. | 2016-07-25 13:38:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:38:45
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:38:45
socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:38:45
socket (14) | SSL has been shut down. | 2016-07-25 13:38:45
socket (14) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:38:45
socket (14) | Shutdown and closed. | 2016-07-25 13:38:45
CQG FIX: Disconnected. | 2016-07-25 13:38:45
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:38:48
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:38:48
socket (16) | Connected. | 2016-07-25 13:38:48
socket (16) | Starting TLS 1.2 connection. | 2016-07-25 13:38:48
socket (16) | SSL connection established. | 2016-07-25 13:38:48
CQG FIX: Sending the Logon message. | 2016-07-25 13:38:48
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:38:48
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:48
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:48
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:48
CQG FIX | FCM name: AMP | 2016-07-25 13:38:49
CQG WebAPI websocket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:38:55
CQG WebAPI websocket (17) | Shutdown and closed. | 2016-07-25 13:38:55
CQG WebAPI | Websocket closed. | 2016-07-25 13:38:55
CQG FIX Trading | Websocket closed. | 2016-07-25 13:38:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:38:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:38:55
CQG FIX: DisconnectFIX called. | 2016-07-25 13:38:55
CQG FIX: Sending a Logout message. | 2016-07-25 13:38:55
CQG FIX Trading | Disconnected. | 2016-07-25 13:38:55
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:38:55
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:38:55
socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:38:55
socket (16) | SSL has been shut down. | 2016-07-25 13:38:55
socket (16) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:38:55
socket (16) | Shutdown and closed. | 2016-07-25 13:38:55
CQG FIX: Disconnected. | 2016-07-25 13:38:55
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:38:59
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:38:59
socket (18) | Connected. | 2016-07-25 13:38:59
socket (18) | Starting TLS 1.2 connection. | 2016-07-25 13:38:59
socket (18) | SSL connection established. | 2016-07-25 13:38:59
CQG FIX: Sending the Logon message. | 2016-07-25 13:38:59
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:38:59
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:59
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:59
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:59
CQG FIX | FCM name: AMP | 2016-07-25 13:38:59
CQG WebAPI websocket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:39:06
CQG WebAPI websocket (19) | Shutdown and closed. | 2016-07-25 13:39:06
CQG WebAPI | Websocket closed. | 2016-07-25 13:39:06
CQG FIX Trading | Websocket closed. | 2016-07-25 13:39:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:06
CQG FIX: DisconnectFIX called. | 2016-07-25 13:39:06
CQG FIX: Sending a Logout message. | 2016-07-25 13:39:06
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:06
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:06
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:39:06
socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:06
socket (18) | SSL has been shut down. | 2016-07-25 13:39:06
socket (18) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:06
socket (18) | Shutdown and closed. | 2016-07-25 13:39:06
CQG FIX: Disconnected. | 2016-07-25 13:39:06
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:09
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:09
socket (20) | Connected. | 2016-07-25 13:39:09
socket (20) | Starting TLS 1.2 connection. | 2016-07-25 13:39:09
socket (20) | SSL connection established. | 2016-07-25 13:39:09
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:09
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:39:09
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:39:09
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:39:09
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:39:09
CQG FIX | FCM name: AMP | 2016-07-25 13:39:09
CQG WebAPI websocket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:39:10
CQG WebAPI websocket (21) | Shutdown and closed. | 2016-07-25 13:39:10
CQG WebAPI | Websocket closed. | 2016-07-25 13:39:10
CQG FIX Trading | Websocket closed. | 2016-07-25 13:39:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:10
CQG FIX: DisconnectFIX called. | 2016-07-25 13:39:10
CQG FIX: Sending a Logout message. | 2016-07-25 13:39:10
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:10
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:39:10
socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:10
socket (20) | SSL has been shut down. | 2016-07-25 13:39:10
socket (20) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:10
socket (20) | Shutdown and closed. | 2016-07-25 13:39:10
CQG FIX: Disconnected. | 2016-07-25 13:39:10
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:13
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:13
socket (22) | Connected. | 2016-07-25 13:39:13
socket (22) | Starting TLS 1.2 connection. | 2016-07-25 13:39:13
socket (22) | SSL connection established. | 2016-07-25 13:39:14
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:14
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:39:14
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:39:14
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:39:14
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:39:14
CQG FIX | FCM name: AMP | 2016-07-25 13:39:14
CQG WebAPI websocket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:39:21
CQG WebAPI websocket (23) | Shutdown and closed. | 2016-07-25 13:39:21
CQG WebAPI | Websocket closed. | 2016-07-25 13:39:21
CQG FIX Trading | Websocket closed. | 2016-07-25 13:39:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:21
CQG FIX: DisconnectFIX called. | 2016-07-25 13:39:21
CQG FIX: Sending a Logout message. | 2016-07-25 13:39:21
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:21
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:39:21
socket (22) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:21
socket (22) | SSL has been shut down. | 2016-07-25 13:39:21
socket (22) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:21
socket (22) | Shutdown and closed. | 2016-07-25 13:39:21
CQG FIX: Disconnected. | 2016-07-25 13:39:21
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:24
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:24
socket (24) | Connected. | 2016-07-25 13:39:24
socket (24) | Starting TLS 1.2 connection. | 2016-07-25 13:39:24
socket (24) | SSL connection established. | 2016-07-25 13:39:24
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:24
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:39:24
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:39:24
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:39:24
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:39:24
CQG FIX | FCM name: AMP | 2016-07-25 13:39:24
CQG WebAPI websocket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:39:26
CQG WebAPI websocket (25) | Shutdown and closed. | 2016-07-25 13:39:26
CQG WebAPI | Websocket closed. | 2016-07-25 13:39:26
CQG FIX Trading | Websocket closed. | 2016-07-25 13:39:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:26
CQG FIX: DisconnectFIX called. | 2016-07-25 13:39:26
CQG FIX: Sending a Logout message. | 2016-07-25 13:39:26
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:26
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:39:26
socket (24) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:26
socket (24) | SSL has been shut down. | 2016-07-25 13:39:26
socket (24) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:26
socket (24) | Shutdown and closed. | 2016-07-25 13:39:26
CQG FIX: Disconnected. | 2016-07-25 13:39:26
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:29
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:29
socket (26) | Connected. | 2016-07-25 13:39:29
socket (26) | Starting TLS 1.2 connection. | 2016-07-25 13:39:29
socket (26) | SSL connection established. | 2016-07-25 13:39:29
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:29
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:39:29
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:39:29
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:39:29
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:39:29
CQG FIX | FCM name: AMP | 2016-07-25 13:39:29
CQG WebAPI websocket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:39:30
CQG WebAPI websocket (27) | Shutdown and closed. | 2016-07-25 13:39:30
CQG WebAPI | Websocket closed. | 2016-07-25 13:39:30
CQG FIX Trading | Websocket closed. | 2016-07-25 13:39:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:30
CQG FIX: DisconnectFIX called. | 2016-07-25 13:39:30
CQG FIX: Sending a Logout message. | 2016-07-25 13:39:30
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:30
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:30
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:39:30
socket (26) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:30
socket (26) | SSL has been shut down. | 2016-07-25 13:39:30
socket (26) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:30
socket (26) | Shutdown and closed. | 2016-07-25 13:39:30
CQG FIX: Disconnected. | 2016-07-25 13:39:30
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:33
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:33
socket (28) | Connected. | 2016-07-25 13:39:33
socket (28) | Starting TLS 1.2 connection. | 2016-07-25 13:39:33
socket (28) | SSL connection established. | 2016-07-25 13:39:34
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:34
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:39:34
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:39:34
socket (28) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:34
socket (28) | SSL has been shut down. | 2016-07-25 13:39:34
socket (28) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:34
socket (28) | Shutdown and closed. | 2016-07-25 13:39:34
CQG FIX: Disconnected. | 2016-07-25 13:39:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:34
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:34
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:37
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:37
socket (29) | Connected. | 2016-07-25 13:39:38
socket (29) | Starting TLS 1.2 connection. | 2016-07-25 13:39:38
socket (29) | SSL connection established. | 2016-07-25 13:39:38
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:38
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:39:38
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:39:38
socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:38
socket (29) | SSL has been shut down. | 2016-07-25 13:39:38
socket (29) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:38
socket (29) | Shutdown and closed. | 2016-07-25 13:39:38
CQG FIX: Disconnected. | 2016-07-25 13:39:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:38
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:38
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:41
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:41
socket (31) | Connected. | 2016-07-25 13:39:41
socket (31) | Starting TLS 1.2 connection. | 2016-07-25 13:39:41
socket (31) | SSL connection established. | 2016-07-25 13:39:41
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:42
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:39:42
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:39:42
socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:42
socket (31) | SSL has been shut down. | 2016-07-25 13:39:42
socket (31) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:42
socket (31) | Shutdown and closed. | 2016-07-25 13:39:42
CQG FIX: Disconnected. | 2016-07-25 13:39:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:42
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:42
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:45
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:45
socket (32) | Connected. | 2016-07-25 13:39:45
socket (32) | Starting TLS 1.2 connection. | 2016-07-25 13:39:45
socket (32) | SSL connection established. | 2016-07-25 13:39:45
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:45
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:39:45
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:39:45
socket (32) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:45
socket (32) | SSL has been shut down. | 2016-07-25 13:39:45
socket (32) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:45
socket (32) | Shutdown and closed. | 2016-07-25 13:39:45
CQG FIX: Disconnected. | 2016-07-25 13:39:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:45
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:45
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:48
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:48
socket (33) | Connected. | 2016-07-25 13:39:48
socket (33) | Starting TLS 1.2 connection. | 2016-07-25 13:39:48
socket (33) | SSL connection established. | 2016-07-25 13:39:48
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:48
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:39:49
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:39:49
socket (33) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:49
socket (33) | SSL has been shut down. | 2016-07-25 13:39:49
socket (33) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:49
socket (33) | Shutdown and closed. | 2016-07-25 13:39:49
CQG FIX: Disconnected. | 2016-07-25 13:39:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:49
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:49
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:49
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:39:51
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:39:51
socket (34) | Connected. | 2016-07-25 13:39:52
socket (34) | Starting TLS 1.2 connection. | 2016-07-25 13:39:52
socket (34) | SSL connection established. | 2016-07-25 13:39:52
CQG FIX: Sending the Logon message. | 2016-07-25 13:39:52
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:39:52
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:39:52
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:39:52
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:39:52
CQG FIX | FCM name: AMP | 2016-07-25 13:39:52
CQG WebAPI websocket (35) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:39:59
CQG WebAPI websocket (35) | Shutdown and closed. | 2016-07-25 13:39:59
CQG WebAPI | Websocket closed. | 2016-07-25 13:39:59
CQG FIX Trading | Websocket closed. | 2016-07-25 13:39:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:39:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:39:59
CQG FIX: DisconnectFIX called. | 2016-07-25 13:39:59
CQG FIX: Sending a Logout message. | 2016-07-25 13:39:59
CQG FIX Trading | Disconnected. | 2016-07-25 13:39:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:39:59
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:39:59
socket (34) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:39:59
socket (34) | SSL has been shut down. | 2016-07-25 13:39:59
socket (34) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:39:59
socket (34) | Shutdown and closed. | 2016-07-25 13:39:59
CQG FIX: Disconnected. | 2016-07-25 13:39:59
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:02
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:02
socket (36) | Connected. | 2016-07-25 13:40:02
socket (36) | Starting TLS 1.2 connection. | 2016-07-25 13:40:02
socket (36) | SSL connection established. | 2016-07-25 13:40:02
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:02
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:40:03
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:40:03
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:40:03
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:40:03
CQG FIX | FCM name: AMP | 2016-07-25 13:40:03
CQG WebAPI websocket (37) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-07-25 13:40:16
CQG WebAPI websocket (37) | Shutdown and closed. | 2016-07-25 13:40:16
CQG WebAPI | Websocket closed. | 2016-07-25 13:40:16
CQG FIX Trading | Websocket closed. | 2016-07-25 13:40:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:16
CQG FIX: DisconnectFIX called. | 2016-07-25 13:40:16
CQG FIX: Sending a Logout message. | 2016-07-25 13:40:16
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:16
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:40:16
socket (36) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:16
socket (36) | SSL has been shut down. | 2016-07-25 13:40:16
socket (36) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:16
socket (36) | Shutdown and closed. | 2016-07-25 13:40:16
CQG FIX: Disconnected. | 2016-07-25 13:40:16
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:19
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:19
socket (38) | Connected. | 2016-07-25 13:40:19
socket (38) | Starting TLS 1.2 connection. | 2016-07-25 13:40:19
socket (38) | SSL connection established. | 2016-07-25 13:40:19
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:19
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:19
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:19
socket (38) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:19
socket (38) | SSL has been shut down. | 2016-07-25 13:40:19
socket (38) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:19
socket (38) | Shutdown and closed. | 2016-07-25 13:40:19
CQG FIX: Disconnected. | 2016-07-25 13:40:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:19
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:19
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:19
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:22
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:22
socket (39) | Connected. | 2016-07-25 13:40:22
socket (39) | Starting TLS 1.2 connection. | 2016-07-25 13:40:22
socket (39) | SSL connection established. | 2016-07-25 13:40:23
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:23
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:23
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:23
socket (39) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:23
socket (39) | SSL has been shut down. | 2016-07-25 13:40:23
socket (39) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:23
socket (39) | Shutdown and closed. | 2016-07-25 13:40:23
CQG FIX: Disconnected. | 2016-07-25 13:40:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:23
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:23
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:26
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:26
socket (40) | Connected. | 2016-07-25 13:40:26
socket (40) | Starting TLS 1.2 connection. | 2016-07-25 13:40:26
socket (40) | SSL connection established. | 2016-07-25 13:40:26
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:26
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:26
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:26
socket (40) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:26
socket (40) | SSL has been shut down. | 2016-07-25 13:40:26
socket (40) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:26
socket (40) | Shutdown and closed. | 2016-07-25 13:40:26
CQG FIX: Disconnected. | 2016-07-25 13:40:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:26
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:26
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:29
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:29
socket (41) | Connected. | 2016-07-25 13:40:29
socket (41) | Starting TLS 1.2 connection. | 2016-07-25 13:40:29
socket (41) | SSL connection established. | 2016-07-25 13:40:30
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:30
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:30
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:30
socket (41) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:30
socket (41) | SSL has been shut down. | 2016-07-25 13:40:30
socket (41) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:30
socket (41) | Shutdown and closed. | 2016-07-25 13:40:30
CQG FIX: Disconnected. | 2016-07-25 13:40:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:30
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:30
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:30
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:33
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:33
socket (42) | Connected. | 2016-07-25 13:40:33
socket (42) | Starting TLS 1.2 connection. | 2016-07-25 13:40:33
socket (42) | SSL connection established. | 2016-07-25 13:40:33
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:33
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:33
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:33
socket (42) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:33
socket (42) | SSL has been shut down. | 2016-07-25 13:40:33
socket (42) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:33
socket (42) | Shutdown and closed. | 2016-07-25 13:40:33
CQG FIX: Disconnected. | 2016-07-25 13:40:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:33
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:33
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:36
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:36
socket (43) | Connected. | 2016-07-25 13:40:37
socket (43) | Starting TLS 1.2 connection. | 2016-07-25 13:40:37
socket (43) | SSL connection established. | 2016-07-25 13:40:37
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:37
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:37
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:37
socket (43) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:37
socket (43) | SSL has been shut down. | 2016-07-25 13:40:37
socket (43) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:37
socket (43) | Shutdown and closed. | 2016-07-25 13:40:37
CQG FIX: Disconnected. | 2016-07-25 13:40:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:37
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:37
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:40
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:40
socket (44) | Connected. | 2016-07-25 13:40:40
socket (44) | Starting TLS 1.2 connection. | 2016-07-25 13:40:40
socket (44) | SSL connection established. | 2016-07-25 13:40:40
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:40
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:40:41
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:40:41
socket (44) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:41
socket (44) | SSL has been shut down. | 2016-07-25 13:40:41
socket (44) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:41
socket (44) | Shutdown and closed. | 2016-07-25 13:40:41
CQG FIX: Disconnected. | 2016-07-25 13:40:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:41
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:41
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:40:44
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:40:44
socket (45) | Connected. | 2016-07-25 13:40:44
socket (45) | Starting TLS 1.2 connection. | 2016-07-25 13:40:44
socket (45) | SSL connection established. | 2016-07-25 13:40:44
CQG FIX: Sending the Logon message. | 2016-07-25 13:40:44
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:40:45
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:40:45
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:40:45
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:40:45
CQG FIX | FCM name: AMP | 2016-07-25 13:40:45
CQG WebAPI websocket (46) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-07-25 13:40:57
CQG WebAPI websocket (46) | Shutdown and closed. | 2016-07-25 13:40:57
CQG WebAPI | Websocket closed. | 2016-07-25 13:40:57
CQG FIX Trading | Websocket closed. | 2016-07-25 13:40:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:40:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:40:57
CQG FIX: DisconnectFIX called. | 2016-07-25 13:40:57
CQG FIX: Sending a Logout message. | 2016-07-25 13:40:57
CQG FIX Trading | Disconnected. | 2016-07-25 13:40:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:40:57
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:40:57
socket (45) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:40:57
socket (45) | SSL has been shut down. | 2016-07-25 13:40:57
socket (45) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:40:57
socket (45) | Shutdown and closed. | 2016-07-25 13:40:57
CQG FIX: Disconnected. | 2016-07-25 13:40:57
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:01
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:01
socket (47) | Connected. | 2016-07-25 13:41:01
socket (47) | Starting TLS 1.2 connection. | 2016-07-25 13:41:01
socket (47) | SSL connection established. | 2016-07-25 13:41:01
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:01
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:01
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:01
socket (47) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:01
socket (47) | SSL has been shut down. | 2016-07-25 13:41:01
socket (47) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:01
socket (47) | Shutdown and closed. | 2016-07-25 13:41:01
CQG FIX: Disconnected. | 2016-07-25 13:41:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:01
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:01
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:04
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:04
socket (48) | Connected. | 2016-07-25 13:41:04
socket (48) | Starting TLS 1.2 connection. | 2016-07-25 13:41:04
socket (48) | SSL connection established. | 2016-07-25 13:41:05
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:05
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:41:05
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:41:05
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:41:05
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:41:05
CQG FIX | FCM name: AMP | 2016-07-25 13:41:05
CQG WebAPI websocket (49) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-07-25 13:41:18
CQG WebAPI websocket (49) | Shutdown and closed. | 2016-07-25 13:41:18
CQG WebAPI | Websocket closed. | 2016-07-25 13:41:18
CQG FIX Trading | Websocket closed. | 2016-07-25 13:41:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:18
CQG FIX: DisconnectFIX called. | 2016-07-25 13:41:18
CQG FIX: Sending a Logout message. | 2016-07-25 13:41:18
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:18
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:18
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:41:18
socket (48) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:18
socket (48) | SSL has been shut down. | 2016-07-25 13:41:18
socket (48) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:18
socket (48) | Shutdown and closed. | 2016-07-25 13:41:18
CQG FIX: Disconnected. | 2016-07-25 13:41:18
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:21
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:21
socket (50) | Connected. | 2016-07-25 13:41:21
socket (50) | Starting TLS 1.2 connection. | 2016-07-25 13:41:21
socket (50) | SSL connection established. | 2016-07-25 13:41:21
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:21
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:41:21
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:41:21
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:41:21
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:41:21
CQG FIX | FCM name: AMP | 2016-07-25 13:41:21
CQG WebAPI websocket (51) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:41:22
CQG WebAPI websocket (51) | Shutdown and closed. | 2016-07-25 13:41:22
CQG WebAPI | Websocket closed. | 2016-07-25 13:41:22
CQG FIX Trading | Websocket closed. | 2016-07-25 13:41:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:22
CQG FIX: DisconnectFIX called. | 2016-07-25 13:41:22
CQG FIX: Sending a Logout message. | 2016-07-25 13:41:22
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:22
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:41:23
socket (50) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:23
socket (50) | SSL has been shut down. | 2016-07-25 13:41:23
socket (50) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:23
socket (50) | Shutdown and closed. | 2016-07-25 13:41:23
CQG FIX: Disconnected. | 2016-07-25 13:41:23
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:26
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:26
socket (52) | Connected. | 2016-07-25 13:41:26
socket (52) | Starting TLS 1.2 connection. | 2016-07-25 13:41:26
socket (52) | SSL connection established. | 2016-07-25 13:41:26
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:26
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:27
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:27
socket (52) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:27
socket (52) | SSL has been shut down. | 2016-07-25 13:41:27
socket (52) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:27
socket (52) | Shutdown and closed. | 2016-07-25 13:41:27
CQG FIX: Disconnected. | 2016-07-25 13:41:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:27
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:27
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:29
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:30
socket (53) | Connected. | 2016-07-25 13:41:30
socket (53) | Starting TLS 1.2 connection. | 2016-07-25 13:41:30
socket (53) | SSL connection established. | 2016-07-25 13:41:30
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:30
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:30
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:30
socket (53) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:30
socket (53) | SSL has been shut down. | 2016-07-25 13:41:30
socket (53) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:30
socket (53) | Shutdown and closed. | 2016-07-25 13:41:30
CQG FIX: Disconnected. | 2016-07-25 13:41:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:30
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:30
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:30
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:33
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:33
socket (54) | Connected. | 2016-07-25 13:41:33
socket (54) | Starting TLS 1.2 connection. | 2016-07-25 13:41:33
socket (54) | SSL connection established. | 2016-07-25 13:41:33
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:34
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:34
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:34
socket (54) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:34
socket (54) | SSL has been shut down. | 2016-07-25 13:41:34
socket (54) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:34
socket (54) | Shutdown and closed. | 2016-07-25 13:41:34
CQG FIX: Disconnected. | 2016-07-25 13:41:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:34
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:34
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:37
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:37
socket (55) | Connected. | 2016-07-25 13:41:37
socket (55) | Starting TLS 1.2 connection. | 2016-07-25 13:41:37
socket (55) | SSL connection established. | 2016-07-25 13:41:37
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:37
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:37
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:37
socket (55) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:37
socket (55) | SSL has been shut down. | 2016-07-25 13:41:37
socket (55) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:37
socket (55) | Shutdown and closed. | 2016-07-25 13:41:37
CQG FIX: Disconnected. | 2016-07-25 13:41:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:37
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:37
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:40
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:40
socket (57) | Connected. | 2016-07-25 13:41:40
socket (57) | Starting TLS 1.2 connection. | 2016-07-25 13:41:40
socket (57) | SSL connection established. | 2016-07-25 13:41:40
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:41
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:41
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:41
socket (57) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:41
socket (57) | SSL has been shut down. | 2016-07-25 13:41:41
socket (57) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:41
socket (57) | Shutdown and closed. | 2016-07-25 13:41:41
CQG FIX: Disconnected. | 2016-07-25 13:41:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:41
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:41
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:44
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:44
socket (58) | Connected. | 2016-07-25 13:41:44
socket (58) | Starting TLS 1.2 connection. | 2016-07-25 13:41:44
socket (58) | SSL connection established. | 2016-07-25 13:41:44
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:44
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:44
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:44
socket (58) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:44
socket (58) | SSL has been shut down. | 2016-07-25 13:41:44
socket (58) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:44
socket (58) | Shutdown and closed. | 2016-07-25 13:41:44
CQG FIX: Disconnected. | 2016-07-25 13:41:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:44
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:44
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:47
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:47
socket (59) | Connected. | 2016-07-25 13:41:47
socket (59) | Starting TLS 1.2 connection. | 2016-07-25 13:41:47
socket (59) | SSL connection established. | 2016-07-25 13:41:47
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:47
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:48
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:48
socket (59) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:48
socket (59) | SSL has been shut down. | 2016-07-25 13:41:48
socket (59) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:48
socket (59) | Shutdown and closed. | 2016-07-25 13:41:48
CQG FIX: Disconnected. | 2016-07-25 13:41:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:48
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:48
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:48
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:51
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:51
socket (60) | Connected. | 2016-07-25 13:41:51
socket (60) | Starting TLS 1.2 connection. | 2016-07-25 13:41:51
socket (60) | SSL connection established. | 2016-07-25 13:41:51
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:51
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:41:52
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:41:52
socket (60) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:41:52
socket (60) | SSL has been shut down. | 2016-07-25 13:41:52
socket (60) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:41:52
socket (60) | Shutdown and closed. | 2016-07-25 13:41:52
CQG FIX: Disconnected. | 2016-07-25 13:41:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:41:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:41:52
CQG FIX Trading | Disconnected. | 2016-07-25 13:41:52
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:41:52
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:41:54
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:41:54
socket (61) | Connected. | 2016-07-25 13:41:55
socket (61) | Starting TLS 1.2 connection. | 2016-07-25 13:41:55
socket (61) | SSL connection established. | 2016-07-25 13:41:55
CQG FIX: Sending the Logon message. | 2016-07-25 13:41:55
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:41:55
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:41:55
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:41:55
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:41:55
CQG FIX | FCM name: AMP | 2016-07-25 13:41:55
CQG WebAPI websocket (62) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-07-25 13:42:09
CQG WebAPI websocket (62) | Shutdown and closed. | 2016-07-25 13:42:09
CQG WebAPI | Websocket closed. | 2016-07-25 13:42:09
CQG FIX Trading | Websocket closed. | 2016-07-25 13:42:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:09
CQG FIX: DisconnectFIX called. | 2016-07-25 13:42:09
CQG FIX: Sending a Logout message. | 2016-07-25 13:42:09
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:09
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:42:09
socket (61) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:09
socket (61) | SSL has been shut down. | 2016-07-25 13:42:09
socket (61) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:09
socket (61) | Shutdown and closed. | 2016-07-25 13:42:09
CQG FIX: Disconnected. | 2016-07-25 13:42:09
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:12
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:12
socket (63) | Connected. | 2016-07-25 13:42:12
socket (63) | Starting TLS 1.2 connection. | 2016-07-25 13:42:12
socket (63) | SSL connection established. | 2016-07-25 13:42:12
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:12
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:42:12
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:42:12
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:42:12
CQG FIX | FCM name: AMP | 2016-07-25 13:42:12
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:42:12
CQG WebAPI websocket (64) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:42:19
CQG WebAPI websocket (64) | Shutdown and closed. | 2016-07-25 13:42:19
CQG WebAPI | Websocket closed. | 2016-07-25 13:42:19
CQG FIX Trading | Websocket closed. | 2016-07-25 13:42:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:19
CQG FIX: DisconnectFIX called. | 2016-07-25 13:42:19
CQG FIX: Sending a Logout message. | 2016-07-25 13:42:19
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:19
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:19
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:42:19
socket (63) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:19
socket (63) | SSL has been shut down. | 2016-07-25 13:42:19
socket (63) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:19
socket (63) | Shutdown and closed. | 2016-07-25 13:42:19
CQG FIX: Disconnected. | 2016-07-25 13:42:19
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:22
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:22
socket (65) | Connected. | 2016-07-25 13:42:22
socket (65) | Starting TLS 1.2 connection. | 2016-07-25 13:42:22
socket (65) | SSL connection established. | 2016-07-25 13:42:22
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:22
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:42:22
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:42:22
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:42:22
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:42:22
CQG FIX | FCM name: AMP | 2016-07-25 13:42:23
CQG WebAPI websocket (66) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:42:24
CQG WebAPI websocket (66) | Shutdown and closed. | 2016-07-25 13:42:24
CQG WebAPI | Websocket closed. | 2016-07-25 13:42:24
CQG FIX Trading | Websocket closed. | 2016-07-25 13:42:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:24
CQG FIX: DisconnectFIX called. | 2016-07-25 13:42:24
CQG FIX: Sending a Logout message. | 2016-07-25 13:42:24
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:24
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:42:24
socket (65) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:24
socket (65) | SSL has been shut down. | 2016-07-25 13:42:24
socket (65) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:24
socket (65) | Shutdown and closed. | 2016-07-25 13:42:24
CQG FIX: Disconnected. | 2016-07-25 13:42:24
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:27
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:27
socket (67) | Connected. | 2016-07-25 13:42:27
socket (67) | Starting TLS 1.2 connection. | 2016-07-25 13:42:27
socket (67) | SSL connection established. | 2016-07-25 13:42:27
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:28
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:42:28
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:42:28
socket (67) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:28
socket (67) | SSL has been shut down. | 2016-07-25 13:42:28
socket (67) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:28
socket (67) | Shutdown and closed. | 2016-07-25 13:42:28
CQG FIX: Disconnected. | 2016-07-25 13:42:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:28
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:28
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:28
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:31
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:31
socket (68) | Connected. | 2016-07-25 13:42:31
socket (68) | Starting TLS 1.2 connection. | 2016-07-25 13:42:31
socket (68) | SSL connection established. | 2016-07-25 13:42:31
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:31
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:42:31
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:42:31
socket (68) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:31
socket (68) | SSL has been shut down. | 2016-07-25 13:42:31
socket (68) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:31
socket (68) | Shutdown and closed. | 2016-07-25 13:42:31
CQG FIX: Disconnected. | 2016-07-25 13:42:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:31
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:31
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:34
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:34
socket (69) | Connected. | 2016-07-25 13:42:34
socket (69) | Starting TLS 1.2 connection. | 2016-07-25 13:42:34
socket (69) | SSL connection established. | 2016-07-25 13:42:34
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:35
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:42:35
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:42:35
socket (69) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:35
socket (69) | SSL has been shut down. | 2016-07-25 13:42:35
socket (69) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:35
socket (69) | Shutdown and closed. | 2016-07-25 13:42:35
CQG FIX: Disconnected. | 2016-07-25 13:42:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:35
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:35
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:38
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:38
socket (70) | Connected. | 2016-07-25 13:42:38
socket (70) | Starting TLS 1.2 connection. | 2016-07-25 13:42:38
socket (70) | SSL connection established. | 2016-07-25 13:42:38
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:38
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:42:38
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:42:38
socket (70) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:38
socket (70) | SSL has been shut down. | 2016-07-25 13:42:38
socket (70) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:38
socket (70) | Shutdown and closed. | 2016-07-25 13:42:38
CQG FIX: Disconnected. | 2016-07-25 13:42:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:38
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:38
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:41
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:41
socket (71) | Connected. | 2016-07-25 13:42:41
socket (71) | Starting TLS 1.2 connection. | 2016-07-25 13:42:41
socket (71) | SSL connection established. | 2016-07-25 13:42:41
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:42
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:42:42
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:42:42
socket (71) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:42
socket (71) | SSL has been shut down. | 2016-07-25 13:42:42
socket (71) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:42
socket (71) | Shutdown and closed. | 2016-07-25 13:42:42
CQG FIX: Disconnected. | 2016-07-25 13:42:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:42
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:42
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:45
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:45
socket (72) | Connected. | 2016-07-25 13:42:45
socket (72) | Starting TLS 1.2 connection. | 2016-07-25 13:42:45
socket (72) | SSL connection established. | 2016-07-25 13:42:45
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:46
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-07-25 13:42:46
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-07-25 13:42:46
socket (72) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:46
socket (72) | SSL has been shut down. | 2016-07-25 13:42:46
socket (72) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:46
socket (72) | Shutdown and closed. | 2016-07-25 13:42:46
CQG FIX: Disconnected. | 2016-07-25 13:42:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:46
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:46
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:49
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:49
socket (73) | Connected. | 2016-07-25 13:42:49
socket (73) | Starting TLS 1.2 connection. | 2016-07-25 13:42:49
socket (73) | SSL connection established. | 2016-07-25 13:42:49
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:49
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:42:49
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:42:49
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:42:49
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:42:49
CQG FIX | FCM name: AMP | 2016-07-25 13:42:49
CQG WebAPI websocket (74) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:42:56
CQG WebAPI websocket (74) | Shutdown and closed. | 2016-07-25 13:42:56
CQG WebAPI | Websocket closed. | 2016-07-25 13:42:56
CQG FIX Trading | Websocket closed. | 2016-07-25 13:42:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:42:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:42:56
CQG FIX: DisconnectFIX called. | 2016-07-25 13:42:56
CQG FIX: Sending a Logout message. | 2016-07-25 13:42:56
CQG FIX Trading | Disconnected. | 2016-07-25 13:42:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:42:56
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:42:56
socket (73) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:42:56
socket (73) | SSL has been shut down. | 2016-07-25 13:42:56
socket (73) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:42:56
socket (73) | Shutdown and closed. | 2016-07-25 13:42:56
CQG FIX: Disconnected. | 2016-07-25 13:42:56
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:42:59
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:42:59
socket (75) | Connected. | 2016-07-25 13:42:59
socket (75) | Starting TLS 1.2 connection. | 2016-07-25 13:42:59
socket (75) | SSL connection established. | 2016-07-25 13:42:59
CQG FIX: Sending the Logon message. | 2016-07-25 13:42:59
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:42:59
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:42:59
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:42:59
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:42:59
CQG FIX | FCM name: AMP | 2016-07-25 13:42:59
CQG WebAPI websocket (76) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:43:01
CQG WebAPI websocket (76) | Shutdown and closed. | 2016-07-25 13:43:01
CQG WebAPI | Websocket closed. | 2016-07-25 13:43:01
CQG FIX Trading | Websocket closed. | 2016-07-25 13:43:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-25 13:43:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-25 13:43:01
CQG FIX: DisconnectFIX called. | 2016-07-25 13:43:01
CQG FIX: Sending a Logout message. | 2016-07-25 13:43:01
CQG FIX Trading | Disconnected. | 2016-07-25 13:43:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-25 13:43:01
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-07-25 13:43:01
socket (75) | SSL shutdown indicates not able to send 'close notify'. | 2016-07-25 13:43:01
socket (75) | SSL has been shut down. | 2016-07-25 13:43:01
socket (75) | SSL object has been freed. SSL state is now disconnected. | 2016-07-25 13:43:01
socket (75) | Shutdown and closed. | 2016-07-25 13:43:01
CQG FIX: Disconnected. | 2016-07-25 13:43:01
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-07-25 13:43:04
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-07-25 13:43:04
socket (77) | Connected. | 2016-07-25 13:43:04
socket (77) | Starting TLS 1.2 connection. | 2016-07-25 13:43:04
socket (77) | SSL connection established. | 2016-07-25 13:43:04
CQG FIX: Sending the Logon message. | 2016-07-25 13:43:04
CQG FIX Trading | Connected to trading server. | 2016-07-25 13:43:04
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:43:04
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:43:04
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:43:04
CQG FIX | FCM name: AMP | 2016-07-25 13:43:04
[2016-07-25 22:20:47]
These are the relevant messages:
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-07-25 13:38:01
CQG WebAPI | Connecting to websocket server. | 2016-07-25 13:38:01
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-07-25 13:38:01
CQG FIX | FCM name: AMP | 2016-07-25 13:38:01
CQG WebAPI websocket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-25 13:38:07
CQG WebAPI websocket (9) | Shutdown and closed. | 2016-07-25 13:38:07
Based on the fact that we do not have any other reports of this, we ourselves can connect to the CQG Web API server and that the connection to the FIX server is succeeding, we suspect this problem is due to a firewall on your computer blocking the connection. The Windows firewall is not going to be a problem.
Refer to help topic 1.2:
https://www.sierrachart.com/index.php?l=doc/helpdetails1.php#h1.2
Date Time Of Last Edit: 2016-07-25 22:21:24
