Date/Time: Sun, 24 Nov 2024 01:23:11 +0000
setting chart
View Count: 2088
[2013-07-18 09:42:37] |
User17612 - Posts: 3 |
hello sorry for my bad english i have this graphic that you can see it: http://screencast.com/t/x97kfRSy i have a simple moving average lenght 30 i want other two line first: sma + 12pt second: sma - 12pt how can i do? thank you |
[2013-07-18 10:28:47] |
Use the Study Subgraph Add study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s272 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-23 15:39:19] |
Hello Today i made login at the 07.57.15 But every one hour i'm disconnected See here: http://screencast.com/t/vDuXF5j5pKKl I have the last version Thank you |
[2013-07-23 16:56:16] |
Refer to the Trading Requirement section at the bottom of this page here: http://www.sierrachart.com/index.php?l=doc/Rithmic.php#TradingRequirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-12 13:30:46] |
Hello I have a problem with login I have this error: http://screencast.com/t/QwVxncx018s can you help me? Pierpaolo Licari |
[2013-09-12 19:37:24] |
You have received an "OS Error" from the Rithmic API. This is outside of our control. It is documented at step 17 here: http://www.sierrachart.com/index.php?l=doc/Rithmic.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-12 19:38:39
