Date/Time: Thu, 09 Jan 2025 09:15:35 +0000
inconsistent Number Bars Candle body color vs HL Bar overlay
View Count: 1256
[2016-07-24 21:34:07] |
JohnR - User831573 - Posts: 307 |
I am using a NumberBar / FootPrint style chart and have selected to use Candle Body outline to get a sense of direction. I wanted some way to see the wicks, which I could not find an option to accomplish this in Number Bars. So, I created a 2nd chart using the same chart settings, and then added an Overlay (Bar) and selected H/L Bar as the style. It looks good in all cases except when the NumberBar candle body is only 1 tick tall. In a fair # of bars, which I have looked at, it appears the Numbers Bar Candle body is one color and the H/L Bar overlay is another. My first request would be for Number Bars to offer Candle Sticks, not just Candle Body as an option, then a 2nd chart and using it as an overlay is not needed. My second request is to have all bar style have the same colors for the same candle formation. John |
2016-07-24_16-55-26.png / V - Attached On 2016-07-24 21:31:40 UTC - Size: 16 KB - 295 views |
[2016-07-26 02:58:57] |
This will be reviewed.
[2016-08-03 10:07:31] |
This will be solved in the next release: My second request is to have all bar style have the same colors for the same candle formation.
Also you do not need a second chart. The Overlay study can reference the very same chart it is on. That will work just fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
