Date/Time: Wed, 08 Jan 2025 17:42:08 +0000
Main task bar pop up menu sorting
View Count: 805
[2016-07-22 17:27:49] |
trader1 - Posts: 128 |
Hi, Would it be possible to sort the main task bar pop up menu alphabetically like the CW sorts the pages? That would save a click every time you want to switch to a page if the main page is covered. You could just use the task bar pop up instead of having to bring the main page to the front and then using the CW button. This would be very useful for those of us that have multiple detached pages. Thanks. Date Time Of Last Edit: 2016-07-22 17:28:43
[2016-07-22 17:49:24] |
Possibly by changing the order of the charts through Window >> Windows and Chartbooks. Refer to: Window, CB and CW Menus: Windows and Chartbooks (Window) Also detached charts have a CW menu as well. Update Sierra Chart: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-22 18:00:10] |
Actually I am aware of the items you mentioned. I am asking if it would be possible for you guys to code the task bar pop up window menu so that it sorts alphabetically like the CW button does. Thanks. (I guess with the Main Page staying on top of the list). Date Time Of Last Edit: 2016-07-22 18:04:45
[2016-07-22 18:52:43] |
No, this is not possible.
