Date/Time: Wed, 08 Jan 2025 18:04:28 +0000
Market Depth Historical Graph
View Count: 964
[2016-07-22 16:38:59] |
User529762 - Posts: 25 |
HI Support, I have 2 issues regarding the Study. Firstly when the Dom is open and displaying the Bid,Ask contracts the 10 levels, if the market has moved a good range the numbers cannot be read as they are scrunched up and on top of each other. Not sure how to get around this ? Maybe stagger them ? Another issue is when you draw a Rectangle on the chart , the rectangle will stop where there is a liquidity band. I think drawings should overide the liquidity levels on the study. |
Attachment Deleted. |
[2016-07-22 16:50:10] |
You need to decrease range of prices on the chart Scale so the depth quantities are not so close together. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html#Range Another issue is when you draw a Rectangle on the chart , the rectangle will stop where there is a liquidity band. I think drawings should overide the liquidity levels on the study.
We do not understand this.
[2016-07-22 17:08:44] |
Thank you for reply, yes this will adjust the scale but will also change the chart scale which is not ideal, there must be another solution.. The other issue. When you draw a Rectangle or Extending Rectangle on the chart with Market Depth the Rectangle drawing will stop or go as far as the Liquidity level drawn by the Market Depth , it will not extend passed or through the level. See picture |
Drawing.png / V - Attached On 2016-07-22 17:08:17 UTC - Size: 7.72 KB - 338 views Attachment Deleted. |
[2016-07-22 17:28:39] |
You can reduce the size of the text. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTradingCustomizingGraphics.php#FontSettings We think we understand the problem with the Rectangle drawings now. You need to change a setting to cause them to display above the Market Depth Historical Graph study: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
