Date/Time: Wed, 08 Jan 2025 17:57:31 +0000
Unable to connect
View Count: 603
[2016-07-22 07:59:03] |
User68127 - Posts: 23 |
Unable to connect to Sierra chart today ? Sierra chart login error : HTTP error : Failed to establish a connexion for the request Thank you |
[2016-07-22 08:35:45] |
This is most likely caused by a firewall on your computer. Refer to this page for solutions: http://www.sierrachart.com/index.php?page=doc/doc_HTTPCommunicationErrors.php We apologize for the delay with the response. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
