Date/Time: Wed, 08 Jan 2025 18:04:59 +0000
Mini Nikkei (Yen) Index Futures Sept 2016 Contract P&L Col on DOM not correct
View Count: 963
[2016-07-22 00:52:39]
User299392 - Posts: 216
So, the deal is P&L Column on the DOM and the NPL information on the top left of the DOM (not chart DOM) just the DOM - is not computing the running P&L accurately.
It is essentially showing every marginal tick to be 1000 yen, when for a fact this contract is worth only 500 yen per tick.
Help, please!
[2016-07-22 01:44:22]
We do show the Currency Value Per Tick for this symbol as 500. Select Chart >> Chart Settings >> Advanced Settings 2. What is the Currency Value Per Tick setting there?
Date Time Of Last Edit: 2016-07-22 01:44:48
[2016-07-22 02:02:03]
It was automatically set to 1000. Not sure why was the feed sending down to populate that feed to be 1000 in case of the this symbol.
I just changed it to 500 manually. Is that right thing to do when it shows up wrongly?
[2016-07-22 03:37:26]
Yes that is fine.
Update the Symbol Settings following these instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
Also refer to this page:
https://www.sierrachart.com/index.php?page=doc/helpdetails77.html
