Date/Time: Wed, 08 Jan 2025 17:25:28 +0000
Exporting Continuous Tick
View Count: 794
[2016-07-21 19:56:19] |
brcrude - Posts: 7 |
I am having trouble exporting continuous tick data from charts. I have followed the instructions posted for setting up a continuous contract and it works in the sierra chart software but when I export the data I only get the tick data for the current month and it goes back further than I set the chart up for. Any ideas or help would be appreciated.
[2016-07-22 04:50:12] |
The behavior you are seeing is expected. To do what you want requires that you use this command instead: https://www.sierrachart.com/index.php?page=doc/EditMenu.html#ExportBarDatatoText However, really it is not recommended because setting the chart bars to 1 tick per bar and exporting a continuous futures contract chart is going to take a long time and freeze Sierra Chart during that time. The file size will also be huge. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-22 12:12:16] |
Thank you for your help. I was able to export data in 1 min increments which will work for me.
