Date/Time: Wed, 08 Jan 2025 18:09:28 +0000
how to remove a candle bar
View Count: 910
[2016-07-21 14:26:58] |
User378226 - Posts: 15 |
Is there a way to remove a specific candle bar in sierra chart? My chart for crude futures has a bar that shows 0.11 at 18:00 on July 20, this threw the chart off and I would like to remove this bar. I can use Ctrl-G to avoid overnight session and the chart would look fine, but would like to see the overnight pattern without this particular bar. I tried to reboot and reload the chart and this bar won't go away. Thanks, Mike Date Time Of Last Edit: 2016-07-21 14:37:59
[2016-07-21 17:23:34] |
Follow the instructions here to correct the data: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-22 01:03:21] |
thanks!
