Date/Time: Wed, 08 Jan 2025 18:12:08 +0000
Incorrect High and Low on CL Daily Historical chart for today (21 July 2016)
View Count: 739
[2016-07-21 09:53:59]
User13668 - Posts: 294
Attached is a screen grab of the CME's web page for September CL oil for today's activity so far - shows Open, High, Low and Last.
My own INTRADAY charts agree with the O/H/L.
However the DAILY HISTORICAL chart is way off showing a Low of 44.55 and a High of 46.13. The Open is correct. See attached SC chart image.
I have tried Edit > Download Data - Historical Chart. Nothing changed.
PS: just noticed that the incorrect High and Low happen to be exactly the High and Low for 20th July (yesterday) - somehow the data is mixing the 2 days
Date Time Of Last Edit: 2016-07-21 09:59:22
imageCMEOilCapture.PNG / V - Attached On 2016-07-21 09:53:39 UTC - Size: 53.6 KB - 274 views
imageCL-201609-CME [CBV] Daily #15 2016-07-21 05_45_40.627.png / V - Attached On 2016-07-21 09:53:49 UTC - Size: 35.13 KB - 263 views
[2016-07-21 10:00:44]
Above post has been edited.
[2016-07-21 10:12:36]
Refer to help topic 2.2:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.2 Historical Charts
[2016-07-21 10:23:59]
Okay, I had to manually edit the file following instructions in 2.2.1
This is because Window>>Current Quote Window is showing the correct data.
So not sure if you want to pass this on to whoever supplies the Daily data as it will not adopt the correct numbers if you just re-load the data.
[2016-07-21 10:37:44]
This data is from our data provider. We expect it will be corrected by the end of the day.
