Date/Time: Fri, 18 Sep 2026 21:11:13 +0000
Connection failure with TTnet/AMP Thursday July 21st - 5am US ET
View Count: 1320
[2016-07-21 09:17:34]
User13668 - Posts: 296
Is there a known problem connecting to AMP/TTnet this morning??
Log below:
Reading Internal Order ID file. | 2016-07-21 05:13:04
Reading Trade Orders file. | 2016-07-21 05:13:04
Reading Trade Positions file. | 2016-07-21 05:13:04
Software version: 1420 | 2016-07-21 05:13:04
Uses New Spreadsheets | 2016-07-21 05:13:04
Enabled for: Advanced Features. | 2016-07-21 05:13:04
Enabled for: Sierra Chart Historical Data Service. | 2016-07-21 05:13:04
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-07-21 05:13:04
Current selected Data/Trading service: AMP/TTNet | 2016-07-21 05:13:04
Chart Update Interval: 500 | 2016-07-21 05:13:04
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-07-21 05:13:04
2016-07-21 10:13:14 Local computer time | 2016-07-21 05:13:04
2016-07-21 09:13:14 Local computer time in UTC | 2016-07-21 05:13:04
2016-07-21 05:13:14 Local computer time in SC Time Zone | 2016-07-21 05:13:04
2016-07-21 09:13:15 Server time in UTC | 2016-07-21 05:13:04
Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-07-21 05:13:04
Program path: C:\SierraChart\ | 2016-07-21 05:13:04
Data Files path: C:\SierraChart\Data\ | 2016-07-21 05:13:04
OS Version Number: 6.2 | 2016-07-21 05:13:04
Locale Setting: C | 2016-07-21 05:13:04
Checking for new symbol settings for tt | 2016-07-21 05:13:04
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-07-21 05:13:04
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-07-21 05:13:04
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-07-21 05:13:04
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-07-21 05:13:04
Symbol settings are up-to-date for tt | 2016-07-21 05:13:04
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-07-21 05:13:17
HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-07-21 05:13:17
AMP/TTNet | Connecting. | 2016-07-21 05:13:20
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2016-07-21 05:13:20
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-07-21 05:13:20
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-07-21 05:13:20
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-07-21 05:13:20
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-07-21 05:13:20
HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-07-21 05:13:22
HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-07-21 05:13:22
TT FIX Data socket (5) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-07-21 05:13:41
TT FIX Data socket (5) | Shutdown and closed. | 2016-07-21 05:13:41
TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2016-07-21 05:13:41
TT FIX Data: Disconnected. | 2016-07-21 05:13:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-21 05:13:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-21 05:13:41
AMP/TTNet | Disconnected. | 2016-07-21 05:13:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-21 05:13:41
AMP/TTNet | Connecting. | 2016-07-21 05:13:44
TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2016-07-21 05:13:44
File >> Disconnect selected. | 2016-07-21 05:14:00
TT FIX Data: DisconnectFIX called. | 2016-07-21 05:14:00
TT FIX Data socket (6) | Shutdown and closed. | 2016-07-21 05:14:00
TT FIX Data: Disconnected. | 2016-07-21 05:14:00
AMP/TTNet | Disconnected. | 2016-07-21 05:14:00
[2016-07-21 09:22:21]
Adam - Posts: 141
i think there is a wider AMP issue
i cant access via CQG and thier account page is down
[2016-07-21 09:26:29]
Adam - Posts: 141
if you are coming in via the UK there is major outages with the backbone. To the USA.
[2016-07-21 09:27:13]
Just got hold of Jeff at AMP via Web chat.
yes there is a known issue this morning with TTnet and TT are working on it
PS: thanks Adam - I am coming via UK
Date Time Of Last Edit: 2016-07-21 09:27:44
[2016-07-21 09:29:00]
Adam - Posts: 141
i cant even get to www.theice.com ....
im back up now via CGQ but routing on IP address
