Date/Time: Wed, 08 Jan 2025 17:27:15 +0000
using the chart values windows
View Count: 546
[2016-07-21 04:38:41] |
User607495 - Posts: 10 |
How do get the chart values windows to give the value over each individual bar or candle as I use the crosshair. It seems to be stuck on;last the day traded and won"t changed value when I scroll back in time.. Thx
[2016-07-21 05:23:42] |
You need to use the Window >> Tool Values Window. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
