Date/Time: Wed, 08 Jan 2025 17:28:50 +0000
Calculation of the bin number of volume by price
View Count: 652
[2016-07-20 19:38:40] |
User381102 - Posts: 7 |
Hello, may I ask how the number of bins of volume by price is calculated (formula)? Is it like: bins = ceil( (high of period - low of period) / ticks per bar ) + 1 Thank you! |
[2016-07-20 22:10:19] |
We do not understand the question.
[2016-07-20 22:20:22] |
OK we understand. We just were confused by the term bins. If you are talking about the number of horizontal volume bars, that generally is correct but not so certain about the ceiling function.
[2016-07-20 23:18:59] |
Thanks. Yes, I was referring to calculating number of horizontal volume bars. By ceiling I'm referring to rounding to lowest integer that is greater than a number e.g. ceil( 7.3 ) would result to 8. So in your case it is just bins = (high of period - low of period) / ticks per bar + 1 without rounding? |
[2016-07-21 05:22:15] |
We cannot answer this question because this is not how Sierra Chart is doing the calculation. Generally that does seem to make sense, but this is the relevant documentation: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#TicksperVolumeBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
