Date/Time: Wed, 08 Jan 2025 17:38:02 +0000
Wrong Pivot Point Formula
View Count: 565
[2016-07-20 12:30:52] |
User571352 - Posts: 2 |
The following formula in Formula Type 10 for Pivot Point calculation is wrong: Support Level 4 (S4) = S3 - (S2 - S1) It should be (S4) = S3 - (S1 - S2) as S1 is higher than S2. Otherwise S4 is above S3 which is obviously wrong. |
[2016-07-20 17:08:34] |
This will be corrected in the next release.
[2016-07-20 17:33:33] |
This is now corrected. We were relying upon a formula we were given or were referencing and trusted it was corrected
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-20 17:34:05
