Date/Time: Wed, 08 Jan 2025 17:28:06 +0000
Order Error
View Count: 540
[2016-07-20 08:25:38] |
User26753 - Posts: 43 |
Today it has been the first day I have placed live trading orders. I was correctly connected to Interactive Brokers. I have placed an stop limit order. One or two minutes after I placed the order it was cancelled with the two legends I have attached. What is the problem? Can you help me? I need to trade from the chart. Regards |
Secuencia 1.PNG / V - Attached On 2016-07-20 08:22:58 UTC - Size: 20.78 KB - 226 views Secuencia 2.PNG / V - Attached On 2016-07-20 08:23:09 UTC - Size: 15.96 KB - 225 views |
[2016-07-20 08:27:28] |
These particular symbols are not the correct symbols to use for Forex trading. Refer to this section here: Interactive Brokers Symbols: Forex Symbols For Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
