Date/Time: Wed, 08 Jan 2025 17:47:53 +0000
Trailing Stops questions
View Count: 969
[2016-07-20 08:16:14]
User360283 - Posts: 506
1. If a simple bracket order is generated via Use Attached Orders, and the trade becomes profitable, can the stop loss order be manually changed to a trailing stop.
2. If no Attached Order Simple Bracket is created, how can I manually create a trailing stop when the position is profitable?
[2016-07-20 08:29:51]
1. No, you would have to cancel the existing stop and submit a new trailing stop.
2. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#SendAttachedOrders
Although if you just simply want to send a single Trailing Stop order, then you just submit the Trailing Stop as a simple new order without any Attached Orders.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#TrailingStop
