Date/Time: Wed, 08 Jan 2025 17:36:23 +0000
tile vertically/tile horizontally
View Count: 819
[2016-07-19 20:08:06] |
enantone375 - Posts: 4 |
I'd like to know the reason why the file comes out as in the picture I attached when I opt for the vertical format
SIERRA.PNG / V - Attached On 2016-07-19 20:06:32 UTC - Size: 160.02 KB - 273 views |
[2016-07-20 01:39:15] |
Are those chart windows which appear small, minimized?
[2016-07-20 18:58:37] |
It has these.when I open a chartbook with 4 or 5 charts and I want to display only two, down with those who do not want to see and do tile vertically to display only 2. Sierra obstructs the view displays because those small / minimized.I would like receive the solution of problem.in a proven demo version previously did not detect any problems. thank you Yours sincerely |
[2016-07-20 21:10:37] |
Could you provide your Chartbook so we can test this. Here are instructions to attach it: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile It can be privately attached. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
