Date/Time: Sat, 11 Jan 2025 09:58:02 +0000
Some trade stats issues
View Count: 1024
[2016-07-19 06:13:26] |
User554317 - Posts: 59 |
Hello, I'm currently trading simulated on SC only. For some reason, I cannot work out the trade activity log. Although I have taken mutliple trades, they do not reflect in the trade statistics of the log. It still says $0. I understand this is only showing non-sim trades and the sim trades are on the trade stats for charts tab only? Also yesterday after flattening a position on the dom, the daily P/L remained at zero. How is this possible? Also I do not understand the fill to fill vs flat to flat and also the time that the trade statistics use when calculating the day break? I could really use some help as I am not sure if I have set everything up correctly. Thanks a lot |
[2016-07-19 17:45:28] |
The first step is to use the Trade Activity tab of the Trade Activity Log to make sure the order fills are there. Follow these instructions:https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php . I understand this is only showing non-sim trades and the sim trades are on the trade stats for charts tab only? This is not correct. The Trade Activity Log can show both simulated and non-simulated trading.Also yesterday after flattening a position on the dom, the daily P/L remained at zero. How is this possible? Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_DailyProfitLossValue.html Also I do not understand the fill to fill vs flat to flat Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#OrderFillMatchingMethods Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-19 17:51:53] |
Refer to:https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#DailyStatsResetTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-20 02:19:16] |
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#DailyStatsResetTime I would like to keep the time set to the actual CME server time, so that I have the correct day breaks when the trading day closes in chicaco. How do I go about this? Thanks. |
[2016-07-20 03:09:42] |
Therefore, set the Global Settings >> General Trade Settings >>Daily Stats Reset Time to 17:00:00
[2016-07-20 03:26:26] |
Thank you. Does this also apply to the chart daybreaks?
[2016-07-20 05:22:28] |
One thing that we did not mention is that the setting of 17:00:00 assumes that the global time zone setting in Sierra Chart is set to US Eastern time: https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html What time zone setting are you using? For the Vertical Grid used in the chart, that follows the Session Times. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VerticalGridLinesAtEvery Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-20 05:34:21] |
Thank you. I have set it to Chicago time, and 17:00 so this should now accurately reflect the CME trading day? Also is there a way to display the globex session and/or the rth session only? And if so is it possible to make them visually different (different background colour) the way Think or Swim does it? |
[2016-07-20 05:43:03] |
In the case of using Chicago time, change the Daily Stats Reset Time to 16:00:00. Also is there a way to display the globex session and/or the rth session only?
Yes this is done through the Session Times for the chart:https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php To highlight the background according to a time range, use this study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s278 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-20 05:48:58] |
Thanks again for that. Regarding the session times, can I just apply the default session times for that instrument rather than having to set it up for every instrument? This is a very error prone approach and I'm sure I'll get it wrong...
[2016-07-20 06:05:17] |
Sierra Chart does not provide default session times for futures. However, we could set these up for you. Give us the main markets that you trade. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-20 06:12:32] |
I really only trade ES and CL at the moment
[2016-07-20 08:33:05] |
No problem. We will set up the session times for these. Just give us about a day.
[2016-07-22 17:46:24] |
The Session Times for these have now been set up. They can be applied to a chart following these instructions: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps However, refer to these instructions here related to this: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-20 10:26:39] |
So I just now need to hit the Apply Global Symbol Settings on both dom's for es/cl? Date Time Of Last Edit: 2016-11-20 10:32:21
[2016-11-20 21:30:08] |
You specifically need to follow through the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
