Date/Time: Wed, 08 Jan 2025 17:28:24 +0000
Request to look at Dow and Dax next to each other
View Count: 633
[2016-07-18 21:16:35] |
User554735 - Posts: 5 |
Hi Please advise how to? Thanks |
[2016-07-19 05:40:13] |
You just open the two charts. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#OpenChart Also refer to the Window Menu page for instructions to tile charts side-by-side: https://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
