Date/Time: Wed, 08 Jan 2025 17:43:49 +0000
How to get rid of extreme bottom right graphic indicating a number?
View Count: 840
[2016-07-18 20:44:36] |
User857142 - Posts: 82 |
Hi - How to get rid of extreme bottom right graphic indicating a number in green highlight? What is it?
[2016-07-19 03:08:50] |
User100134 - Posts: 3 |
http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#LRChartSettingsIndicators What you are seeing is this: [number]: This is the bar spacing in pixels. Not sure if you can remove it, SC will have to answer that one. Date Time Of Last Edit: 2016-07-19 03:11:00
[2016-07-19 05:33:27] |
It cannot be removed but the colors can be changed. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#LRChartSettingsIndicators Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-19 20:09:07] |
Hi - It only gets rid of the background color and not the entire thing. I mean can I customize the font color too for e.g. 5L something?
[2016-07-19 23:10:25] |
The font color is going to be the same as the Chart Text color.
