Date/Time: Wed, 08 Jan 2025 17:45:46 +0000
Point and Figure
View Count: 932
[2016-07-18 15:19:01]
User66682 - Posts: 12
The Point and Figure chart only has X's. How do we get O's for down movement?
[2016-07-18 17:18:58]
[2016-07-18 18:53:36]
http://www.sierrachart.com/image.php?Image=1468867982258.png
[2016-07-19 05:47:15]
Use the Point and Figure Bar setting in Chart >> Chart Settings:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#PointAndFigureBar
We do not know what you are doing to cause those X's to display. It does not appear as though you are using either the Chart Setting or the Point and Figure Chart study.
[2016-07-19 13:42:06]
I am set to Chart-Chart Settings- Point and Figure (In Graph Draw Type)
[2016-07-19 16:35:59]
That is not how you do it.
You need to use
Chart >> Chart Settings >> Intraday Chart Bar Period >> Bar Period Type .
Date Time Of Last Edit: 2016-07-19 16:37:02
[2016-07-19 17:38:09]
Is Bar Period Type Point and Figure? Then what in open slot?
[2016-07-19 17:53:12]
You need to set:
to Point and Figure Bar.
