Date/Time: Wed, 08 Jan 2025 18:02:36 +0000
Can not Down Load Sierra Chart SW.
View Count: 688
[2016-07-18 08:04:19]
User779938 - Posts: 4
Hi I triedd several times to download SC but is does not work.
I just time out with the message showed attached.
I tried to furn off my MCAfee Firewall but the result remain the same.
Hope you can help,
Best regards
Michael
attachmentSierra Installation Problem.docx - Attached On 2016-07-18 08:02:25 UTC - Size: 267.99 KB - 293 views
[2016-07-18 08:10:14]
We need to get the actual Installer Log file itself. Here are the instructions to provide that:
https://www.sierrachart.com/index.php?page=doc/download.php#ProvidingInstallerLogToSupport
[2016-07-18 08:42:04]
Here is the latest file, Thank you.
Date Time Of Last Edit: 2016-07-18 09:09:22
[2016-07-18 09:08:48]
This is not what we need. Once again follow through the instructions here:
The file has a Log extension.
[2016-07-18 09:18:41]
there is only an empty file called C:\sierracharts
[2016-07-18 12:15:45]
I have managed to download now.
thank you,
BR
Michael
[2016-07-18 16:27:09]
This is good. If you still had a problem we would need to use remote assistance to look into this.
