Date/Time: Fri, 28 Feb 2025 13:51:50 +0000
Accessing retracement/projection price with ACSIL
View Count: 2256
[2016-07-17 17:00:59]
User162368 - Posts: 3
I'm working on a trading system that is using the retracement tool.
Is there a way of accessing the price of the different retracements/projections levels from the s_UseTool instance that I created, without having to store them myself when I create the instance?
[2016-07-17 23:30:36]
Yes this can be accessed with the s_UseTool::RetracementLevels member.
Date Time Of Last Edit: 2016-07-17 23:30:50
[2016-07-18 21:16:58]
I am using the s_UseTool::RetracementLevels to set the percentage levels and other visual properties of the retracement tool, but I can't seem to get the PRICE of the levels.
[2016-07-18 21:39:22]
You should have no trouble with this.
Show us the code you are using to get the prices.
[2016-07-19 16:38:53]
Well, right now I am calculating the price from the fib levels, like so
SCFloatArrayRef fib1LevelValues = sc.Subgraph[0].Arrays[0];
SCFloatArrayRef fib2LevelValues = sc.Subgraph[1].Arrays[0];
Tool.RetracementLevels[0] = 100.0f;
Tool.RetracementLevels[1] = 61.8f;
Tool.RetracementLevels[2] = 50.0f;
Tool.RetracementLevels[3] = 38.2f;
Tool.RetracementLevels[4] = 23.6f;
Tool.RetracementLevels[5] = 0.0f;
// Store price for fib1 levels
for (int i = 0; i<6; i++) {
  // Get the retracement level
  float a = Tool.RetracementLevels[i];
  // Calculate the price for current retracement level
  float price = Tool.BeginValue - (Tool.BeginValue - Tool.EndValue) * (a / 100);
  // Set tick size
  float tickSize = 0.25;
  // Round price to the nearest tick
  fib1LevelValues[i] = price - fmod(price, tickSize) + ((fmod(price, tickSize) < tickSize / 2) ? 0.0 : tickSize);
[/i][/i]
I cant find anything in the documentation about getting the price from the RetracementLevels array, only visual properties. But maybe I'm looking in the wrong place?
[2016-07-19 17:25:05]
You need to get the Chart Drawing using this function:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#scGetUserDrawnChartDrawing
You can then use the RetracementLevels array to access the values.
Date Time Of Last Edit: 2016-07-19 17:26:20
[2021-08-24 17:01:54]
User485461 - Posts: 9
@User162368
I'm trying to draw price retracement on every daily candle with only one level.
Do you know is there a way to get it.
