DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:43:09 +0000
OCO when each leg is a bracket order
View Count: 3493
[2016-07-17 14:20:23]
vbmithr - Posts: 204
I'd like to be able to have an OCO buy stop sell stop, and each of the
legs of the OCO would have attached targte/stop orders.
So it's like an OCO of 2 bracket orders. This should be possible, but
under the bracket order transmission mecanism described in DTC I don't
see how to do it. I have yet to check how SC does it, but I'm not sure
it's possible and it probably should.
I think DTC should have a message type SUBMIT_BULK_ORDERS or something
like that, where I could specify several orders and the relationship
between them, as it is done per BitMEX API.
[2016-07-17 16:03:06]
Mmh, I see, the OCO buy stop sell stop is handled server side, while attached orders (bracket orders) are managed server side. Meaning that I need my instance of SC running if I want to use that kind of setup…
[2016-07-17 22:25:04]
DTC Engineering - Posts: 320
The DTC Protocol is meant to be as simple as possible does not support this type of advanced order configuration.
In Sierra Chart when two orders are in an OCO group and each of those orders has their own Attached Orders (Target and Stop), then the OCO functionality for those two orders is managed on the client side.
