Date/Time: Wed, 08 Jan 2025 17:37:55 +0000
Uning Daily OHLC data
View Count: 692
[2016-07-15 13:54:32] |
User360283 - Posts: 506 |
I want to plot the midpoint of the Daily OHLC but when I try do do this using the Study Subgraph Difference But, I do not get the plot. How can I do this? Is there an alternative way bto get access to the Hi and Lo data? |
[2016-07-15 17:50:59] |
jackw - Posts: 57 |
Use the 'Study Subgraphs Average' study. Sample study collection attached.
MidPoint-.StdyCollct - Attached On 2016-07-15 17:50:33 UTC - Size: 9.4 KB - 369 views |
[2016-07-15 18:14:58] |
Refer to the documentation for the Daily OHLC study here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 Specifically refer to the Displaying Midpoint of High and Low Lines section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
