Date/Time: Wed, 08 Jan 2025 17:53:49 +0000
Spreadsheet Study - Automatically Save to File
View Count: 1176
[2016-07-15 08:52:55] |
User47579 - Posts: 4 |
Greetings, From another post I see how to save the data from a Spreadsheet Study to a file... Refer to: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetAdditionalInfo.html#ExportingSheetDataToTextFile Can this be done automatically, I would like to do this at the beginning of a new line (prior bar close), if so how would I do this? Thank you, Bryan |
[2016-07-15 09:02:18] |
No, this cannot be done automatically. You may also be interested in this menu command: https://www.sierrachart.com/index.php?page=doc/doc_EditMenu.html#ExportBarStudyDataToTextFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
