Date/Time: Wed, 08 Jan 2025 18:11:30 +0000
CHART TILING NOT USABLE WITH NEW SC VERSIONS
View Count: 654
[2016-07-15 02:13:31] |
TechTrader - Posts: 116 |
Upgraded from 1426 to 1441 and the chart tiling has changed, upgraded to 1445 and same problem. Any minimised spreadsheets are rendered not visible as the charts take up full window space. Also I had 6 chart windows spaced at 3 vertical and 2 horizontal using the tile vertically/tile horizontally buttons. With the new versions the horizontal tiling produces 6 very narrow charts (unusable) or 6 narrow vertical charts (also unusable). I have reverted back to SC1410.
[2016-07-15 04:54:26] |
We are still working on the new tiling functions. Vertical and horizontal tiling will always tile vertically and horizontally respectively, but the minimum window sizes will be increased. You will want to use the Tile as Grid command and we are adding another one for an alternative configuration. We will solve this: Any minimised spreadsheets are rendered not visible as the charts take up full window space.
