Date/Time: Wed, 08 Jan 2025 17:26:11 +0000
Problems compiling Study
View Count: 864
[2016-07-14 19:26:30]
rwilliams1 - Posts: 346
I tried using a study that I have not used in awhile and it did not work. I found an error message that said the study needed to be recompiled for this version of SC (see Initial error). But when I try to recompile it, I get additional error messages (see Compiler error). Help would be appreciated. Thanks.
Private File
Private File
[2016-07-14 21:20:49]
Rename sc. MouseEventType to sc.PointerEventType in the source code file.
[2016-07-14 22:01:33]
My apologies. I'm not a programmer so I'd like to know if there is a way to automatically rename and replace all the instances of sc.MouseEventType and change it to sc.PointerEventType so that I don't miss anything? Thanks again.
[2016-07-14 22:03:25]
Yes. This is just nothing more than a basic Find and Replace using a text editor.
You can edit the file through Analysis >> New/Open Custom Studies File. Do not have to be a programmer to know how to do this.
